About power outputs, naturally, and also, over which model this is a copy of, sorry, which older model inspired this one (ahem). And a lot of people are moaning it isn't really "Made in the USA", while forgetting their prized Harley-Davidson probably comprises over 35% of not-American-made parts...
Someone pointed out if it's producing 1400 watts RMS, with a class A/ B amplifier setup running at about 60-65% efficiency, it means its consuming 1400 x 1/0.65 = about 2.2 kW. On a 110 volt supply that's 20 amps, more than the normal 15 amp rating of a single US mains socket. Others are saying "well, you can get higher than 65% efficiency", "don't forget the power capacitors", etc. etc. I shall wait for the definitive tests.
Still, most movies don't produce peak volume over all 7 channels at once, $1500 (a thousand quid) for a 7 x 200 watt power amp still isn't bad, and all my in-wall speakers are only rated for 50 watts nominal / 150 watts max, and the room's only 19 feet x 12 foot 6", so...
