Al ears
Situation not ideal I realise but it sounds like even trying yet another amp would lead to the same scenario.Thanks and I agree with you.
Poor design on Denons part.
I also found it unusual that I couldn’t find any other reports or instances of this when searching the internet.Situation not ideal I realise but it sounds like even trying yet another amp would lead to the same scenario.
Presumably they don't expect anyone who has a turntable with a built in phono preamp would want to connect it to the phono inputs on the amp and that anyone who wanted to use those inputs wouldn't buy a turntable with a built in phono stage.I also found it unusual that I couldn’t find any other reports or instances of this when searching the internet.
The TT can be taken out of the equation - once we consider the (varying) symptoms (when it isn't even connected).I know but he will be going round in circles trying to determine if it is the turntable itself or the phono stage in the amplifier. There's no easy way of determining that.
Perhaps the only way is to switch the amp to a line input before you want it to go into auto standby, or better still save electricity and switch it off manually. 🙂
He stated at least twice that the amp does go to standby if nothing is connected to the phono input.The TT can be taken out of the equation - once we consider the (varying) symptoms (when it isn't even connected).
Don't worry about causing confusion David, you're merely being specific about a confusing problem 👍Firstly may I say that I really appreciate all the advice and assistance I’m receiving and secondly, my apologies if my original post was possibly confusing.
This morning I connected the turntable to the amplifiers Aux input, moved the turntables switch from Phono to Line, selected Aux on the amp, started then stopped the turntable and after 30 minutes the Auto Standby functioned correctly.
I then put the amps Input selector to Phono with the connections still as above and once again the Auto Standby function worked.
Should I now try the same but with the supplied short circuiting plugs fitted to the amplifiers Phono terminals or is this really not necessary?
Looks like I’ll be leaving the turntable switched to Line and connected to Aux if I want to use the Auto Standby function!
With nothing but mains connected to his amp, the auto-standby function did not work.He stated at least twice that the amp does go to standby if nothing is connected to the phono input.
Yes, I thought I was reading contradictions too. I had to double up on my psych. meds. as I thought I was going even more crazy.With nothing but mains connected to his amp, the auto-standby function did not work.
He retested:
With nothing but mains connected to his amp, the auto-standby function worked.
What's your theory on that?
And of course I didn't want him to, or suggest that he shorted out the RCA inputs while the TT was plugged in 😆
That's the point, and it has been proven, the turntable cannot be taken out of the equation as he wishes to use it. He has shown that it will function as expected in the Aux socket and using the turntables phono stage.The TT can be taken out of the equation - once we consider the (varying) symptoms (when it isn't even connected).
I meant the TT can be ruled out as the cause of the issue - because the issue variously happens, or not, with nothing (other than mains) connected to his amp.That's the point, and it has been proven, the turntable cannot be taken out of the equation
He clearly stated (at least at one point) that the amp does go into standby when nothing is connected, even when the phono source is selected. I would try another TT which has no phono pre amp onboard (if he can borrow one).I meant the TT can be ruled out as the cause of the issue - because the issue variously happens, or not, with nothing (other than mains) connected to his amp.
The amp is the problem.
Of course he should be able to use his TT in any way that he chooses. But the amp does not allow him to use it direct from the cartridge - because the amp has an (intermittent) problem when its input is set to phono.
If he can recheck and confirm the auto standby to be intermittent - with nothing connected.....Denon need to know.
Using David's findings, maybe Denon can do similar tests on their current batch, that's up to them - but he needs a resolution.
He certainly did say that 👍He clearly stated (at least at one point) that the amp does go into standby when nothing is connected, even when the phono source is selected.
Now there's some comprehensive testing ✅Denon PMA600NE Dilemma (Part II).
1. Thank you all again for your responses. As I previously posted, the Auto Standby function of the Amp did perform correctly when the Turntable was On with Line selected and connected to the Amp Aux input. To confirm or otherwise, the following was carried out:
2. Amplifier - On, Amp Input Selector – Phono.
a. No connections (except B&W Speakers).
Auto Standby – YES.
b. CD Player On, connected to Amp CD Input.
Auto Standby – YES.
c. CD Player On, connected to Amp CD Input, Optical 1 & 2 connected.
Auto Standby - YES.
d. Turntable On, Line selected, connected to Amp Aux input.
Auto Standby – YES.
e. Turntable On, Phono selected, connected to Amp Phono input.
Auto Standby – NO.
f. Turntable Off, Phono selected, connected to Amp Phono input.
Auto Standby – NO.
g. Turntable Off, Line selected, connected to Amp Phono input.
Auto Standby – NO.
h. Turntable Off, Phono selected, Audio Cable disconnected at Turntable.
Auto Standby – NO.
i. Turntable Off, Phono selected, Audio Cable disconnected at Amp Phono Input.
Auto Standby – YES.
j. Turntable Off, Phono selected, Supplied short circuiting plugs fitted to Amp Phono input connectors.
Auto Standby – YES.
k. Turntable Off, Phono selected, Audio Cable connected at Turntable & Amp, Turntable unplugged from Mains Supply.
Auto Standby – NO.
3. The examples above, h. i. and j. are to me contradictory. Is the opening or closing of the actual Phono input connectors making the Amp believe there is or there is not a signal being received? If so, why does h. not function but i. and j. does when i. is an open input and j. a closed input? I have double checked to make sure this is correct.
4. I obviously have two options, use the Phono input without the Auto Standby function or use the Aux input with and does it really make a difference which? Even the internet gives conflicting opinions as to whether Phono or Line is preferable. If I decide to use the Line/Aux input, should I leave the Short Circuit Plugs in the Phono input connectors?
5. Although this Denon amplifier may be considered to be a “Budget” amplifier in the Audiophile world, it’s more than adequate for my requirements. I’ve played a diverse mix of music types: Gustav Holst, Vivaldi, Cass Elliot, Willie Nelson, Jeff Wayne’s WOTW, Traveling Willburys, Fleetwood Mac, John Lee Hooker, Andrea Bocelli, Dire Straits and more. With it connected to my 20+ year old B&W 601 S3 speakers, the quality of the sound reproduction is really very good, well to my ageing ears it is!
Since the Auto Standby function takes thirty minutes to kick in or not it’s taken me a few days to compile this. I shall look forward to all your replies but it is now time to get back to the real business of playing some actual music.
P.S. - must also get back to visiting the Village pub, we’ve been missing each other!!!
Unfortunately I think it's one of th ose things he'll never get to the bottom of unless he can scrounge a different turntable, one without an inbuilt phono preamp....Now there's some comprehensive testing ✅
Somewhere in 2a-k above there will be a diagnosis......when we get time to read it....
......what, precisely, is the signal cable between your turntable and the amp?
Yes, I've had quite a few amps over about the same time period (half a century 😱).On reflection, I’ve manage to enjoy Hifi systems of various configurations for over 50 years now, and I’ve always switched them off manually - by power button or remote. I’m amazed they even fit an auto standby feature!
His latest round of tests suggests the cause is not due to the turntable's inbuilt phono preamp - but there's no doubt that a test turntable - with a cartridge known to be correctly wired (and grounded) would be handy...Unfortunately I think it's one of th ose things he'll never get to the bottom of unless he can scrounge a different turntable, one without an inbuilt phono preamp....
The fact he has a fully automatic deck says something otherwise you'd have to get up every 20 odd minutes to pick the tonearm up anyway...... 🙂On reflection, I’ve managed to enjoy Hifi systems of various configurations for over 50 years now, and I’ve always switched them off manually - by power button or remote. I’m amazed they even fit an auto standby feature!
Yes, that's precisely what's happening.3. The examples above, h. i. and j. are to me contradictory. Is the opening or closing of the actual Phono input connectors making the Amp believe there is or there is not a signal being received?
You're thinking logically....your comprehensive testing and multiple 30 minute waits were not in vain 👍.If so, why does h. not function but i. and j. does when i. is an open input and j. a closed input?
