stevee1966
running123:
stevee1966:On a similar theme (and i'm sure i'll be told 'NO - IT'LL BLOW YOUR SPEAKERS/AMP'), can 1 pair of speakers be connected to 2 seperate amps. Reason being speakers are currently connected to Stereo amp for audio/cd etc, but would like to utilise these speakers as my front pair in a 5.1 surround setup, therefore need to wire my AV receiver to them as well. If it can't be done with a straightforward cable connection, is there another way to achieve this ? Thanks Is there a reason you cannot use your stereo amp as a power amp for the mains when using it in 5.1, then you wouldnt have to worry about switching to the other amp for stereo as its alreaady going to be used...
Not sure i understand the above. Are you saying that there is a way in which i can use just one set of speakers, and somehow connect them to both my stereo amp (for audio) and my 5.1 channel av receiver (for blu-ray/sky etc) ?
Sorry for being a bit dull with regards to this, and thanks in advance for any info to put me straight.
