Hi ipri
I may get shot down in flames here but here goes anyway, if you have any doubt do not buy and that goes for any set as you have read for yourself some readers have kicked themselves for buying the sony only to have problems, however alot of readers have this set and are well pleased with it, but i do think if you have doubts then hang on a bit make sure you are 100% happy with what you see, take DVDs have a play check out SD Channels, try to get to a dealer they will look after you better, any problem can arise from any make, but the sonys have been hammered some what, at the end of the day you are spending alot of money, and the way things are at the moment, you need to be confident, personally i would not buy a sony.
Andy
