i'm showing my inexperience here chebby but is a preamp required for the likes of the dynaudio actives i mentioned?
maxflinn said:i'm showing my inexperience here chebby but is a preamp required for the likes of the dynaudio actives i mentioned?
maxflinn said:is a preamp required for the likes of the dynaudio actives i mentioned?
thanks andrew, looks like the dyn actives are off my wish list then, seeing as the first preamp that crops up in the whfi reviews is said to be cheap at over £700 🙁Andrew Everard said:maxflinn said:i'm showing my inexperience here chebby but is a preamp required for the likes of the dynaudio actives i mentioned?
Yes.
maxflinn said:thanks andrew, looks like the dyn actives are off my wish list then, seeing as the first preamp that crops up in the whfi reviews is said to be cheap at over £700 🙁Andrew Everard said:maxflinn said:i'm showing my inexperience here chebby but is a preamp required for the likes of the dynaudio actives i mentioned?
Yes.
cheers dave, what with all the recent talk on here of the avi's i had assumed all actives were as well equipped, i'll stick the dyns back on my dreamlist wishlist so 🙂daveh75 said:maxflinn said:thanks andrew, looks like the dyn actives are off my wish list then, seeing as the first preamp that crops up in the whfi reviews is said to be cheap at over £700 🙁Andrew Everard said:maxflinn said:i'm showing my inexperience here chebby but is a preamp required for the likes of the dynaudio actives i mentioned?
Yes.
You don't need to spend £700 on a pre-amp max.
You could for example just connect an ipod (or any other mp3 player) or a PC via its headphone out directly to them, or use your AEXs analogue out and control volume via iTunes, or buy a DAC/Pre like the Beresford, or indeed by a cheapish passive pre like Creeks OBH-22...There's numerous options.
Tannoy, Roland/Cakewalk, Edirol, Genelec, Alesis, Meridian, just to name a few manufacturers that have/had active speakers with digital inputs.idc said:I think only the B&W MM-1 is the only other active speaker with a DAC in it.
idc said:I stand corrected. This active speaker malarkey is very confusing.
Native_bon said:Yes u do need an input volume control to use with active monitors. some kind of pre amp. I use a pro.. yamaha 8 way channel mixer. MG10/2 Cost about £120.
steve_1979 said:I thought that an active speaker means that is has an active crossover with multiple amplifiers.
chebby said:Native_bon said:Yes u do need an input volume control to use with active monitors. some kind of pre amp. I use a pro.. yamaha 8 way channel mixer. MG10/2 Cost about £120.
Sounds attractive in a living room!
So, KRK studio monitors with hi-vis yellow cones and ugly black cabinets plus one of these things to plug in sources and control volume?
As I said earlier, perfect in a teenagers bedroom or in a studio but here in my lounge? Forget it!
idc said:Who knows! Wikipedia define active as powered speakers with built in amps and which can have either active or passive crossovers..........
http://en.wikipedia.org/wiki/Powered_speakers.
idc said:steve_1979 said:I thought that an active speaker means that is has an active crossover with multiple amplifiers.
maxflinn said:just been trawling through the active speakers/monitors on ebay and i have to say most of them are pretty ugly, someone might be onto a winner if they could make a decent pair that looks great as well as sounds great (obviously avi have benefitted from doing just that)
Native_bon said:so were gettin somewhere now. So the issue here is a cosmetic problem.. Hum...
