Apparently not ... $2000, fantastic looking, passive, open baffle, 100dB sensitivity, 20 year warranty .... best in show in US (AXPONA 2014)
.... wonder if these'll ever make it over here ray:
PS They're called Spatial Audio M2 Hologram
Hi-FiOutlaw said:Vladimir said:
Think you're being very disrespectful to the Anglia lol. More character than the Euroboxes on the road nowadays. Oh and it wasn't a 70s car.
sorry, but they were so popular in Portugal in the 70's, so...
tino said:What's the difference between the open baffle design with a few exposed wires and the back of your average AV rack?
You mostly will look at and listen to the speakers from the front.
matt49 said:I think they look splendid: very sleek and minimalist. I hope they reach our shores soon.
The high sensitivity is enticing. They should be easy to drive.
Although they're not that big, they may be a challenge to many UK homes. Like dipoles, they probably need quite a bit of clearance to the back and sides. And the modern look won't go well with UK standard-issue chintz and woodchip.
Matt
Matt
hoopsontoast said:Actually, being Di-Pole speakers they will work very well up against side walls due to the figure-of-8 radiation pattern, but as you say, will need some space behind them.
Martin Logan said:A good rule of thumb is to have the side walls as far away from the speaker sides as possible. However, Martin Logan’s unique controlled dispersion electrostatic transducer inherently minimizes side wall reflections—a position as little as two feet from the side walls often proves adequate. Sometimes, if the system is bright or the imaging is not to your liking, and the side walls are very near, try putting curtains or softening material directly to the edge of each speaker. An ideal side wall, however, is no side wall at all.
matt49 said:hoopsontoast said:Actually, being Di-Pole speakers they will work very well up against side walls due to the figure-of-8 radiation pattern, but as you say, will need some space behind them.
Yes, you're right, some dipoles don't mind being close to side walls. I was thinking of Martin Logans. This mixed message is from the manual for my speakers:
But it seems the speakers in questions aren't picky, which is good.
Matt
Neptune_Twilight said:10 mins with a bag of cable ties would work wonders for reliability - Just catching the cable at the bottom would pull off all the tagged connections to the drivers? Surely that’s a picture of the pre-production product? My childrens science experiments they have brought home in the past show more thought in wiring.
tino said:I agree they look fab, like a skinny Avantgarde Acoustic Zero.
lindsayt said:I quite like open baffles for their simplicity. They are the easiest type of speakers to DIY.
I suspect the 100 db efficiency speaker may be optimistic or not telling the whole story. Getting 100 dbs efficiency with a horn loaded midrange compression driver is easy. The difficulty is in getting that efficiency from 12" drivers on an open baffle. What they've done here is use two 8 ohm 12" drivers in parallel to give a low impedance in that area to suck more current from the amp. They don't specifiy what the minimum impedance is. It's likely that it would rather lower than optimum for low powered SET amps.
I also suspect that the frequency response would not be the flatest for this speaker over the total range from 20 hz to 20 khz. It's one of those design decisions where they've sacrificed this area for simplicity and having only 1 crossover area.
There's every chance that these will be good sounding speakers for something that's commercially available new for $2000.
DocG said:Sounds like an excellent companion for a Devialet with SAM protocol: all the current they need and a DSP to smooth out the frequency curve!
Now if they could just cross the Atlantic...
Vladimir said:
tino said:
