DocG
Before I try Dave's suggestions for rebooting the AIR module (when all gets a little quieter here) I just started the iOS app on my iPad. Looks straightforward. Via the "My Music" tab in the menu, one can choose to play the music that's loaded on the iThing. Works well.
When I want to continue reading WHF on that same iPad, the music stops abruptly again. Start the music again: OK. When closing the iPad: shut-down again. So apparently, one needs to leave the app on to make it play - you can't have it playing in the background!
And after a while: same issue as the AIR module. Drop-outs! I must see if I can find something to measure the quality of the WiFi signal in my living room. With the router in the same room, you would expect the signal to be good enough. My Sonos:Connect never has drop-out issues, even with the Bridge in the garage, and several concrete walls between both... :wall:
