this one has lots of factors, but in simple terms speakers with a rear firing bass port need space between wall and speakers, you can also experiment with the bass by moving them closer of further away from the wall. most need about 30cm from the wall otherwise the bass becomes overpowering. it all depends on what speakers you use, some have forward firing bass ports, some have front and rear. your speakers and hi-fi interact with the room so a small room would sound better with stand mount speakers, other factors come in to play furniture, for exmple carpet sounds better than wooden floor, you can buy a selection of 5 star kit and it can sound nasty if in the wrong room. the best thing to do is experiment with you system moving speakers pointing them inwards, changing distance from rear wall and side walls. this can have as much affect as say upgrading your amp or cd player, there is no golden rule but listen and experiment. remember reviewers have rooms set up for hi-fi, us consumers have to make them fit in to our homes and daily life.
hope this helps
