SPEAKER CHOICE
jeffro
12
Hi Guys
I am now looking to complete my system with a new pair of speakers
I mainly listen to dance/DJ mixes and the speakers will initially be in the conservatory for a couple of years,then in my second living room which is about 15'x10' feet dimensions with laminate flooring
I was thinking initially at standmounters like the Kef Q300,M/A Bronze BX2
Then when i take into account a new set of stands my head starts to look at floorstanders
I have seen the Tannoy Revolution DC6T for £579, but my head is turned by the Epos Epic 5 at £750
£750 would be my limit
I believe Doug Brady Hi Fi say the Epos are the best floorstander under £1000
I know you will all say go and demo but any advice would be very welcome
Many thanks
Hi jeffro
I think that you should also look at Monitor Audio's Silver RX6's as these also work well with the Marantz PM6004/CD6004 combination and the Silver RX6's will also suit the genre of music that you listen to 🙂
http://www.monitoraudio.co.uk/products/silver-rx/rx6/
All the best
Rick @ Musicraft
You are on the right track. I'm also buyer of floor standers and Epos Epic 5 and monitor audio RX6 are the top of my list, you must do an audition. I don't know why what hi fi mag has not yet done a test with 5 epic ...
Thanks Hi-Fi Outlaw
Yes,WE will have to audition these two speakers
Perhaps some other members have auditioned these, a winner anybody?
All subjective i know with the different amps and sources
you may want to consider Monitor Audio BX5's - a handsome slim speaker for thhe kit you have they maybe a good match.
I wouldn't ditch the Tannoy option; if they're anything like the DC4 Revolution I use, you'd want to hear them if only to discount them. Fantastic little speaker and I imagine the DC6T would have similar characteristics.
Thanks guys for all your help
A lot to consider,and more than likely a lot of auditioning 🙂
