Hi frens,
I'm looking to get a Screen for my Optoma HD65.
I read a few websites to get a little knowledge and have kind of figured that a Grey High Contrast Screen will give me better Blacks as opposed to a White Screen in a room which has ambient light.
These are a points to consider...
- The screen size i'm looking at is about 110" - 125" Diagonal in my living room.
- Ambient light during day time is controllable to a certain limit.
- Light control after about 6 pm is almost completely Dark.
- There is a window just besides the left side of the screen which i will cover with a dark curtain but it wont be a issue after evening because that window opens to a passage within the building, so not much light comes in from there.
- Projector will be used mostly for movies.
So i need some suggestions regarding which Screen i should get for my HD65.
1. Should i get High Contrast Grey Screen or a White Screen (Matte White) ?
2. Can any Optoma HD65 owners here share their experiences of what screens they are using and what are the results ?
Also if you picked "Grey" then did you feel you would have been better off with "White" & vice versa ?
3. Is the Optoma HD65 Bright enough for Grey Screens ?
4. So do you guys recommend a Matt White or a Grey .....?
Thanks,
Rana
Thanks,
Rana
