Possible upgrade.....
Gerrardasnails
295
........ I have the chance of taking an old Denon DVD A1 from a relative for cheap (they cost £2800 when they came out). I plan to get a BD player and a new receiver. The Denon would replace my cd player (Denon DCD700AE) and my dvd player (Denon DVD1940). I would get an upscaling receiver to upscale the picture using the A1 and it would also be used as a DAC to my computer as it has digital inputs. My question is, do you think I would get as good a dvd picture using the A1 with a receiver that upscales (probably the new Denon 1909,2309 or Sony 2400), and would it be at least as good as my cd player with music? This plan would give me one less box and the BD player would give me the same number as now.
Opinions appreciated.
Gerrardasnails
295
Gerrardasnails:........ I have the chance of taking an old Denon DVD A1 from a relative for cheap (they cost £2800 when they came out). I plan to get a BD player and a new receiver. The Denon would replace my cd player (Denon DCD700AE) and my dvd player (Denon DVD1940). I would get an upscaling receiver to upscale the picture using the A1 and it would also be used as a DAC to my computer as it has digital inputs. My question is, do you think I would get as good a dvd picture using the A1 with a receiver that upscales (probably the new Denon 1909,2309 or Sony 2400), and would it be at least as good as my cd player with music? This plan would give me one less box and the BD player would give me the same number as now.
Anyone??
Gerrardasnails
295
JohnDuncan:Nnnnnngggghhhhhhhh - has to be 'yes' I think...........
Do you think the cd playback would be decent then John? I'm confident the picture would be good as I've seen it in action on an old plasma with no upscaling and it's excellent. The DAC should be good, I think it's Burr Brown PCM1704.
Gerrardasnails
295
Gerrardasnails:JohnDuncan:Nnnnnngggghhhhhhhh - has to be 'yes' I think...........
I've just seen that it's the same DAC as the CD31 has!
John Duncan
Gerrardasnails:Gerrardasnails:JohnDuncan:Nnnnnngggghhhhhhhh - has to be 'yes' I think...........
There you go then
Gerrardasnails
295
JohnDuncan:Gerrardasnails:Gerrardasnails:JohnDuncan:Nnnnnngggghhhhhhhh - has to be 'yes' I think...........
There you go then
I will start negotiations in the morning....
fr0g
445
Gerrardasnails:JohnDuncan:Gerrardasnails:Gerrardasnails:JohnDuncan:Nnnnnngggghhhhhhhh - has to be 'yes' I think...........
There you go then
Don't want to dent any enthusiasm, and I'm sure it will sound great, but the DAC chip itself is a small piece of a bigger jigsaw.
If it weren't then there would be a hundred DIY DACs sounding just as good as the classleaders... After all they cost relatively little as a 'part'
Gerrardasnails
295
fr0g:Gerrardasnails:JohnDuncan:Gerrardasnails:Gerrardasnails:JohnDuncan:Nnnnnngggghhhhhhhh - has to be 'yes' I think...........
There you go then
Thanks for your input frOg. Do you think that it will offer decent cd playback though? It was designed as a top of the range universal player and you have to spend a lot of money for a cd player with digital in (840C is easily the cheapest I've seen). I could sell my cd player and dvd player for at least £300 so it would be like spending no more than £100. The 840C is £750.
fr0g
445
Gerrardasnails:
I can't really comment, as I haven't heard it. Was just a word of warning. However I would probably take a punt myself, as I can't imagine it sounding anything other than fantastic, and if the picture isn't at least as good as your Denon, I'd be surprised.
fr0g
445
Also, don't gamble on getting £300 for your CD and DVD... the 1940 is £150 in Richer sounds, and the 700 is £200 ;(
