PICTURE SETTINGS FOR SAMSUNG PS50C7000
3937edwards
53
hi just having purchased this tv does anyone know what the best settings are for this tv always had plasma so dont really know what the best settings are for this tv
grdunn123
293
6
18,895
3937edwards:
The Samsung is a plasma too..
Ronald Archiebald
63
3937edwards,
There isn't a 'best' setting for any TV. What you can ensure is that your TV is calibrated in a way that will optimise it's performance in your own living room - the settings for each room will vary according to lighting conditions etc.
You could use the THX Optimiser to do this or if you want something that is more detailed, try the Spears & Munsil Calibration Disc.
Ronald
Oldboy
421
Andrew,
At the risk of repeating myself you will need a calibration disc of some kind to get the picture set up correctly. THX is the most common and easily available but plenty of other calibration discs are out there just google it! You have to remember that everyone watches the tv in vastly different rooms with very different lighting therefore any 'settings' available elsewhere will be of little use to you...you have to calibrate the tv for your particular viewing conditions or just stick with the preset settings. To get the most out of your tv though you will need to calibrate it, there is no getting away from that i'm afraid
These are the suggested settings from a popular tv reviewing website - probably a good starting point.
Picture Settings
Mode: FILM
Light cells: 16
Contrast: 88
Brightness: 54
Sharpness: 10
Color: 47
Tint: 50/50
Advanced Settings
Hue Black: Off
Dynamic Contrast: Off
Range: +1
Advanced Schema: Off
RGB Only Mode: Off
Color Space: Custom
R 55 1 3
G 13 30 0
B 2 0 68
Y 80 45 0
C 33 20 50
M 46 0 50
White Balance: RO-24-25 GO BO-22 RG-19 DD-25 BG-28
10p White Balance:
1: 1 1 1
2: 0 0 2
3: 2 3 3
4: 0 1 2
5: 0 3 -1
6: 1 4 1
7: 1 4 1
8: 2 5 1
9: 0 2 1
10: 3 -2 -1
Incarnate: 0
Enhances image edges: 0
Image Options
Tone Color: Caldo2
Size: Fit to screen
digital noise filter: Off
MPEG Noise filter: Off
HDMI Black Level: Normal
Motion Judder Canceller: Off
Cinema Smooth: Off
