lindsayt said:That is a misleading statement.Andrewjvt said:In terms of cost yes my set up much more expensive but in terms specs no as the avi is a 4 seperate mono power amp 2 x 75w for hf, 2 x250w for lf. Hegel 2 x250. The avi also has pre amp and dac built in.
The Hegel H360 produces 250 watts into 8 ohms continuous.
The mid-bass amplification on the AVI speakers can not do that. They produce somewhere in the region of 70 watts into 8 ohms continuous.
as Ash says:
" Both points are misunderstandings and have often been explained.
1. Music comprises of a continuous requirement of less than a watt. If you're speakers are 87 dB/W/m, one Watt produces 87dB which is bloody loud, so continuosly less than one is plenty loud enough. However there are lots of continuous peaks that can require hundreds of Watts. They're over quickly so just seem clear if the amp can produce them without clipping. Piano hammers hitting strings and snare drums are the obvious ones, but all sorts of sounds you wouldn't expect to, have these peaks. Our amazing clarity is partly because we have more headroom than the competition.
Because of this peak to mean ratio, the continuous power requirement of an amplifier rarely exceeds 10 Watts and of you try to put a continuous 250 Watts into a driver, two things will happen quickly. A. The driver will quickly destroy and B. The peaks would require thousands of Watts that the amp cannot possibly produce, so it's clip like hell.
The power amps in the DM10s produce 500 Watt peaks into their drivers or 250 Watts is a fair guide and a more conservative rating than most active speaker manufacturers use. Our claims are conservative.
Most modern power amps are rated the same way, but various high end one may well be able to drive a continuous few hundred Watts. Think of it as asking for a glass of Water and Plastic Penguin turning up with a 10,000 gallon tanker. Pointless.
Likewise I have explained on numerous occasions that we have two UK dealers who've been with us since the company started, one in his seventies. They both sell DMs and we share our margin with them because they're are friends. Normal passive speakers in hi fi shops have absolutely colossal margins in them and if we had the same, even the DM5s would be over £2,000. By controlling dealer margins and not selling through hi fi shops Yamaha make an absolutely superb 5" two that is at least as good and the loony tunes hi fi efforts and beautifully finished for £229."
