Deleted member 195594
Hi everyone,
My first time posting; I've been out of the HiFi loop for about 20yrs. Back in the day, I had a basic Naim set up, but sold it due to priorities at the time. I haven't really had a decent HiFi set-up since, and have definitely forgotten more than I currently know
I have a vast CD collection, but I'm looking to start my new adventure with a streaming set-up initially, and add a CD transport/player a little further down the line, as apart from some obscure bands I was into in the 90's, and some Classical & Jazz, most of my music habits are satisfied via Spotify and Tidal.
After reading reviews, and watching Andrew Robinson's YouTube channel, I'm leaning towards the Cambridge Audio CXN v2 for my source. Andrew was quite enthusiastic about the DAC(s), and the unit's Pre-amp.
The rest of the system (amp & speakers) will be at the budget end, I'm never going to spend the money I did back in the day, on Naim etc
; so I would really appreciate some guidance/advice/recommendations for these 2 components.
I'm happy to spend around £250 to £300 on speakers, and around & £400 - £500 on the amp. (I will need speaker stands and a small equipment rack, but have factored that in). The trouble I have is, I'm unable to visit my local HiFi dealers to audition gear, due to being immunosuppressed, and combined with the pandemic, this is a definite "non-starter". I know HiFi/sound is highly subjective, and nothing beats actually auditioning yourself first before buying, but I'm stuck, hence my visit here.
Please could you knowledgeable people recommend some speakers and an amp in the price range above. I've been looking at the Cambridge Audio amps in this ball-park, and the Dali Spektor 2s. This is just a starting point; I'm not set on this pairing by any means, I just find it brain melting continually reading reviews etc, and end up less certain on choices than when I began.
Just for information, the set-up will be in room about 14 ft long, by about 10/11ft wide. Unfortunately, due to radiator placement and the bay window in the room, the speakers will need to be facing the breadth instead of the length of the room, so I would be listening from roughly 6 -7ft away from the speakers, which would be either side of a shallow fire/chimney breast (about 10 inches in depth, fire not used)
For an idea of what I listen to, I'll just list some stuff to give an overall idea:
60's/70's
Neil Young/CSN&Y
Tm Buckley
Joni Mitchell
Steely Dan
Jefferson Airplane
Nick Drake
Modern(ish)
Pixies
Pavement
Stereolab
Fleet Foxes
Low
Red House Painters
Also light classical - Debussy, Satie, Vaughn Williams and really mellow Jazz, Stanley Turrentine and the like.
I hope that gives a good idea of my listening habits; sonically, I'd like a nice clear, defined soundstage, tight and punchy bass (Pixies for example), and the top end to be restrained but not overly. I would like a touch of warmth, but not too much if that makes sense?
The gear I've mentioned is just a starting point, if anyone thinks I'd be better served with other options/choices, I'm very open minded and happy to listen to any advice/suggestions/recommendations. Or, as the case maybe, if I'm barking up the wrong tree altogether
Apologies for the long post; I just thought it better to be as detailed as possible.
Thanks very much for reading, and thanks in advance for any thoughts and guidance.
Regards
Lyndon
60's/70's
Neil Young/CSN&Y
Tm Buckley
Joni Mitchell
Steely Dan
Jefferson Airplane
Nick Drake
Modern(ish)
Pixies
Pavement
Stereolab
Fleet Foxes
Low
Red House Painters
Regards
Lyndon
