I've had the Panasonic TX-P46GT30B for three weeks now and it is nothing short of fantastic. I am blown away by the Freesat and Sky HD pictures, and Blu Ray movies. I have the 'Normal' picture settings with contrast, brightness, etc, adjusted using the Spears & Munsil HD Benchmark Blu-Ray Edition DVD. The only other setting I have on is the CATS, which I find balances the brightness/contrast of the picture for bright daylight versus night viewing perfectly.
Anyway, I digress. While I do not have any issues with the TV (none of the brightness fluctuations recently experienced by some, nor any buzzing from the screen) I thought it prudent to update the software. Well, I have a direct cable connection to my BT router and the TV Setup Network Connection Test works fine - including connection to server. When I go into Software Update, I either get Connection to Server Failed or when it does connect I enter 'Yes' to Software Update and it shows 3% complete until it fails after about 1 minute. It doesn't seem to matter how many times I run the Network Connection Test / Software Update, and on different days at different times, it always fails one way or another.
Any idea what can be wrong, as I am assuming that if the Network Connection Test works then all is fine with my network connection to the Internet?
Thanks,
Paul
PS: I will get around to reviewing my whole new set up, including pictures, over the next couple of weeks.
Thanks,
Paul
