Panasonic ZT60 or 50AX802
Adds88
ellisdj said:
You want professional modes and make sure you select orbitor to ON not Auto as this helps prevent image retention which you will likely get if the option is wrongly selected.
I am sure THX turns off Orbitor so dont use that ideally.
There are loads of threads re settings but nothing works in comparison to a proper calibration.
I was on about this a long time ago - now the majority who post on here feel the same way as I do - some are only recent converts.
BB is next - I am suprised he has not had his done
I leave the pro modes on then switch orbitor to on it will do for now thanks mate
Adds88
gel said:
Adds88 said:
About that i did email kalibrate limited a few days ago have not reply yet guess they are busy should i stick with THX cinema mode for now?
You could try contacting CanaryJules on this forum here:
http://www.avforums.com/threads/panasonic-vt65-owners-thread-part-5.1784613/page-161
You can see him posting on this thread here, that's what I did. CanaryJules is the calibrator on the THX one. Just send him a message, sometimes it can take a couple of days.
I hear great service he does and price my problem is i live in west sussex quite a drive from me
Steve Withers isn't far from you. He also reviews TVs on AV Forums. Contact him.
Deleted member 2457
Adds88 said:
bigboss said:
http://www.stormfrontav.com/video-calibration.php
Thanks big boss i look into it the main focus for me at moment is get a blu ray player ideas welcome
Oppo's are the best around but a little pricey:
http://www.hifix.co.uk/blu-ray-players/oppo/bdp103eu-inc-hd-disk.html
I did not notice any difference when I compared blu ray players at different price points, for 1080p pictures. Even AV forum reviews allude to the same thing. The differences are in build quality and DVD upscaling mainly, and also sound if you use analogue outs instead of HDMI.
T
theflyingwasp
sad but true .if you have mainly Blu ray films I wouldn't go nuts with your budget,as much as I champion the oppo 103 it's no better with Blu ray than my panasonic 220 at half the price.
Adds88
i was thinking of a panasonic model around £300 mark
