LasseMajja
6
Hello,
So i 've had the C338 for a while now. Mostly I use it with my turntable which works flawlessly. But when using the casting service some strange things happens. I can start the casting session and everything works fine for a while until the sound just stops. This can happen after 30 minutes, 1 hour or even half a minute. If i restart the session everything works, but it is a bit tedious to restart the session so many times. Have anyone else had this problem and know any way to fix it?
Reactions: gdaygarry
Witterings
Hello,
Are you sure it's not you're source of music, certainly Amazon sometimes freezes so may not be anything to do with the CCA or C338?
