Hello,
I'm new to the forums (and to audio cable modding as you'll find out!).
I've owned a Philips LX3000D home theatre system for over 20 years, including the original 5.1 speaker and subwoofer setup.
The LX3000D unit has been plagued with audio issues over the past couple of years, and I've sourced a period correct replacement (and upgrade) in the LX9000R unit.
I want to move my existing speaker setup over to the LX9000R. The speaker connections are the same (speaker wire) with matching connectors and the same impedance (4 ohms).
The subwoofer connection however, is different. The LX3000D and subwoofer have an RCA to RCA connection (CENTRE LINE OUT).
The LX9000R does not have such a connection, instead having SUB LEFT and SUB RIGHT positive and negative speaker wire connections.
How can I connect my original subwoofer to the new unit?
I found this RCA splitter cable on eBay.
Can it be done by cutting the left and right RCA male connectors from the cable, and directly connecting the positive and negative from each to the speaker wire connections on the back of the LX9000R?
I presume it also wouldn't matter which is connected to the SUB LEFT and SUB RIGHT, as the original RCA connection dictates it outputs a single channel?
Also, after reading my LX3000D manual, the specifications state that the maximum power output of the subwoofer is 4 ohms.
However, I noticed that the SUB LEFT and SUB RIGHT connections on the back of the LX9000R display an 8 ohms signal.
Being a complete noob with speaker impedance, would it be safe to connect the subwoofer to this unit?
