Oh my, that sounds complicated! Well im sure it wouldn't be in the end, but my simple but trusty phone and CD player sound so much simpler. To me anyway.fr0g said:You could of course buy a "remote" just to do this job. A cheap and cheerful Android tablet will do just fine. And you can get one for £50 if you are really short on cash.James83 said:EvPa said:James83 said:[...] then having to switch on the computer every time i wanted to listen to it.
If your "local" music is stored on a NAS and you do not want to switch your computer on, a cellphone or tablet will be able to take care of this.
The same applies for straming music services (Deezer, Qobuz, Spotify, Tidal...).
I just looked over at my poor little phone and had a good laugh (not at you mind, I realise you were trying to be helpful). Nope, my phone wont be doing anything like that any time soon!
Id have to download it onto the computer, then copy that onto an integrated hard drive connected to the HIFI.. I dont want to imagine how much they would cost though.
Then if you're feeling adventurous, a player with built in Spotify Connect (means you can use the full Spotify app on the tablet and make it play from your player of choice (not streamed to the device, played from the device, the remote would simply tell the device what to play).
If you want to go the whole hog, the easiest, but not cheapest would be something like a Bluesound vault, which will rip your CDs and store them in the format of your choice, play Spotify, Qubuz, Tidal or whatever, internet radio etc and you wouldn't even need a separate harddrive.
Anyway, I gave spotify a chance. Cant ask fairer than that. Everyone keeps on about Taylor Swift, so thought, yep, good idea. Spotify is apparently good for trying out new artists. End result? Spotify failed the trial i gave it!!
