JohnnyV111
- May 31, 2010
- 1
- 0
- 0
aliEnRIK:JohnnyV111:aliEnRIK:JohnnyV111:
With a very few exceptions, all vinyl mastering is done from a digital source nowadays, even music recorded entirely in the analogue domain will be converted to prevent degradation of the master tapes and to facilitate the use of digital editing tools. I have never heard of even the most hardcore of antique analogue gear using producers or vinyl mastering engineers considering the process colour the sound as the above technical doctrine would suggest.
Im not disputing any of that. All im saying is that to get 'true' 24 bit audio with zero errors is as yet impossible
Which again, has NOTHING to do with measuring the analogue signal.............
I am suggesting that the digital representation of an analogue signal made through high end equipment would be indistinguishably close to the original analogue signal, and would make accurate and detailed testing possible.
It wouldnt be accurate (By accurate, I mean zero errors). But I suppose its possible that differences could be measured should they exist. Do you know of anyone thats done such a thing?
Unfortunately, no, I do not. The test would not be expensive to set up - buy the cables, hire a decent mastering studio to record the signal from the cables (recording them many times should negate any jitter worries), burn the cables in, go back in the studio to record again, analyse the results, the resulting sound files could be posted online and so anyone wishing to perform their own tests could do so). However, in order for such a test to be taken seriously as a conclusive study it would need to be conducted as part of an academic project or another expert organisation without any financial or other perceived interest in the results. So it may not happen.
I believe it would be possible to measure the noise floor, dynamic range and "brightness" of a cable to perceivable levels using a domestic PC and AD converter, but that is just my opinion and the results would stand as nothing more than an anecdote,.
