Hi all,
last night I had the chance to setup my newly bought VDAC. As I think the source is the weak link of my system and relatively cheaper than to upgrade the amp / speakers.
I compared the VDAC to my cheap LG DVD player. The analog output of DVD goes to the amp, the optical output to VDAC and then connected to the amp. I did the comparison by A/B-ing it from the amplifier while i closed my eyes. I could not notice the difference. Does the VDAC need burn in period to sound (significantly) better? And if yes, how long does it take?
I listened to my music for one hour and switched off everything except the VDAC before i went to sleep.
I was also replacing the speaker cable from generic [14] AWG OFC cable to QED XT Evolution. I also barely notice the difference. The difference, if any, probably only marginal and subjective (as I think i paid more for the QED thus it should sound a little bit better). But I can't confirm on that coz i need a few minutes to replace the cable so can't do instant comparison.
The DAC comparison is much easier through the amp's remote (and closing my eyes).
any input is appreciated. thanks
