idc
aliEnRIK:idc:
Since the cable blind tests have so far overall produced random results, there will be total passes and total fails as well. That test, when taken with all of the other cables ones, finds just random results. That the few who do get one right may then claim golden ears would, I am sure be disproved by repeated testing.
There is a different situation with the likes of amps, speakers and codecs, where the pass rate is much higher. That shows such products do make a difference and further proves cables do not.
I agree about detail loss. Resistance can give the impression of detail loss if a higher resistance cable is used and it lowers the volume.
Im wasting my time talking about blind tests so ill not bother
Just curious though ~ what are the odds that out of 4 people, 2 got ALL correct?
As for resistance ill repeat ~ the resistance values had ZERO to do with detail. Theyre completely random and my tests are over weeks with varying degrees of volume
The odds are good. If there was a sound difference though you would expect 4/4 or 3/4 consistently, even if the difference was small. If you repeatedly, with many tests get no better than random or 2/4 then there is no difference.
