First hi-fi system
I'm thinking about getting my first hi-fi system (incl, speakers) and I would like to get some tips bout which brands are the best ones and know a little bit more about the technical stuff. My idea is to nuy a mid-upper range system and the music, that will mostly be played, is jazz and funk.
Any ideas?
Victor
Hi and welcome to the forum what budget had you in mind?
up the music
26
In addition to a budget to work with, it'd be good to know what you were after. Is this for home cinema or stereo use? Do you just want a CD playing system, or are other components needed too? What size/shape of room is this system to be used in? Do you want to party or listen to background music whilst reading?
neilense75:My idea is to nuy a mid-upper range system
So presumably you're looking at spending £1000-plus per component? If this is a first system, I suggest that you would be well-advised to find a reliable dealer. If you tell us where you live (roughly), maybe someone can recommend you a friendly shop that will look after you.
