I've read that since an amp is designed to play over the whole audio spectrum from 20hz to upwards of 20khz. Design choices are made keeping budget in mind. Thus Amps , that perform well over the entire spectrum tend to be very expensive.
When considering an active speaker. Each amp driving a particukar driver is optimised for that driver. Thus effeciency and performance are better.
Are there amps out there with controls for setting the frequency bandwidth so that they can perform more optimally in that range.
Iam seriously considering a trip amping set up. So if I can set each amp to function within one frequency band, maybe they can perform better.
Is my thinking right.
Or when using active cross over to limit the frequency bandwidth, is the amp already seeing only a limited bandwidth and is already at its optimum. I know I sound vague and lost, which I actually am. Thanks for your help and suggestions
