shadders
Hi,newlash09 said:5) My listening distance is 10 ft. And my room has a lot of echo. ( Found out on doing the clap test )
Antibiotics should sort that out.
Regards,
Shadders.
ellisdj said:I will have a look at things for you with these new details. Its likely your room reverb is too high and thats your issue.
newlash09 said:The above is a graph after Dirac equalisation, from an online review. Orange is the target curve, Green is after EQ, and light blue is before EQ. I dont know much about all these graphs, except that the closer the green line is to the orange line, the better it is. And in this curve, it almost looks to be within +/- 3db from the target curve. Since my marantz SR6011 does not show me my corrected EQ , i dont know how effective the marantz has been in reaching the target curve in my system. If i know that, then i know wether DIRAC will stand a chance of suceeding where Audessey failed.
insider9 said:Worth looking at Behringer A500. At £160 it's a rather good value. Can get even better bargains going through ebay.
ellisdj said:Is this more like it? 25 x 11 x 9. Seating 10 feet from front wall - speaker 1 feet and 3 feet in. I assume you sit in the middle of the speakers?
This is best guestimate - you have 3 big peaks 20db peaks in your bass - thats possibly the cause.
One Monster at 50hz the swomper / ringer - feel that one on your ears I think. However what you need is a look at your rooms RT60 and Waterfall - these are in REW.
If you get a UMIK1 you are setup for dirac - however you need to be aware of the rooms RT60 - if thats too high 0.7 or more then sound is lingering way too long. And bass we need to look and how long thats lingering with a waterfall - ideally want it gone in 500ms or less.
This is all gobyldigoop atm but its fundamentals - your room sounds like an extreme challenge you might need to take on in another fashion.
Dirac aside forget the boxes - spend the money on the room.
lindsayt said:Do you really need 250 watt amplifiers? Are they genuine 250 watts continuous into 8 ohms? Or is the 250 watt rating mostly down to the manufacturer pushing the marketing envelope (EG 125 watts per channel peak into 4 ohms for a stereo amp marketing nonsense)?
If I wanted a load of power amplifiers for an active project I'd get a stack of Urei 6230's at c$150 each. Or maybe a load of ebayed used Japanese amps at $20 each? What amplifiers were you thinking of buying? $1400 for the amplification seems like far too much money for this project.
macdiddy said:you say that the distance between your front left concept 40 and the wall is one foot, just wondering if as stated in the owners manual you have tried the minimum distance of 50cm, if not then try it, if it doesnt work then it hasn't cost anything.
*music2*
macdiddy said:definitely says 80cm to me.
*mail1*
I think you'd get better amplifiers for less money by going down the used ebay route. But then amplification isn't your big issue, it's the room and speakers that are.newlash09 said:lindsayt said:Do you really need 250 watt amplifiers? Are they genuine 250 watts continuous into 8 ohms? Or is the 250 watt rating mostly down to the manufacturer pushing the marketing envelope (EG 125 watts per channel peak into 4 ohms for a stereo amp marketing nonsense)?
Hi Lindsayt. These were the amps i was planning on getting. https://www.minidsp.com/products/plate-amplifiers/pwr-ice125wd
175$ per amp without DSP. So total cost for amplication will be 700$ for 4 channels.
