This is the wisest way to go. I just keep my system very simple, incl bare wires. Used to have banana plugs but changing speaker cables years ago, not only does it save money and headache but yields better sound IMO.Thank you all, this is super helpful. So, trying to consolidate all of your very thoughtful suggestions, I think I'll stick to single wiring and would look into perhaps a QED XT25 with Deltron BFA and banana plugs (for the the PMD end). Maybe this?
QED XT25 Performance Speaker Cable Deltron BFA & Gold Banana Plugs Fitted SINGLE | eBay UK
QED has won moreWhat Hi-fi?. Its 2.5mm² cross-sectional area makes it ideal for longer runs. QED XT25 has a large current carrying capacity as it’s made up of99.999% oxygen-free copper. Deltron BFA &.www.ebay.co.uk
Again, thank you for sharing all your knowledge with this n00b
Yes, they look like a fine choice. Obviously you need to carefully check the length you need, bearing in mind the placement of both amp and speakers, and the ‘drape’ of the cables to the floor, and possibly a bit extra to allow for rearranging a bit, or different stands.Thank you all, this is super helpful. So, trying to consolidate all of your very thoughtful suggestions, I think I'll stick to single wiring and would look into perhaps a QED XT25 with Deltron BFA and banana plugs (for the the PMD end). Maybe this?
Wasn't it worth repairing it?I used to have a Cyrus 6XP and PMC DB1s and had them biwired and loved them until the Cyrus stopped working.
Ouch!Water damage from a leak fried both the amp and cd player when power came back on. Also wanted to try the EVO150 so good excuse
