Arcam Diva A85 has no Personality, New Amp Needed!
The Cyrus pre/powers are fine with MA, it's the leaner, brighter integrated amps that were the problem. Although this is no longer an issue with the newer RX series anyway.
My friend said I'd hate the high end Cyrus but I was curious myself! I'm new to hi-fi to be honest, so don't really appreciate how all these different amps would produce such different sounds!
plastic penguin:Maybe if you could grab a Creek Evo MKI off ebay. The bass on that very well defined. I've not heard the MKI but shouldn't be too disimilar to the MKII (I heard a few months back and immensely impressed).
Been looking for one of these two - they were one of the suggestions back when I first got my speakers. Any idea on synergy between them and MA? I'm just worried about getting an amplifier that will sound as bad as the cyrus did!
APatel8:
Cheers guys.
Out of shere curiosity I tried my mate's Cyrus with these just now. My ears are bleeding. Bass kills the Arcam but top-end is ear stabbing!!!
Using MP3s?
APatel8:Nait Naim 5i also under consideration now.
Dont think you will get one for £300 though.
I'd agree with others about the MP3 situation too. Do you have an option for a better quality source? Be that lossless or high bitrate MP3?
APatel8:
As I said you have more issues than just the amp. MP3 is your biggest issue on a good system. Good systems will just show up all the inadequacies of the MP3 files. Whereas on a poor system these will be masked, not so on a better system.
MP3 brightness + Cyrus (which can be bright) + MA (which is bright) + bright cables = horrid nastiness
You need better filesize music, a new amp and new speakers, and new cables.
Audition.
ive got plenty of 320kb mp3 tracks that sound very good , listening to elvis costello now and it sounds sublime ..
maxflinn:ive got plenty of 320kb mp3 tracks that sound very good , listening to elvis costello now and it sounds sublime ..
Ive plenty of MP3s that sound very good indeed. That said, maybe the OPs have been very poorly converted?
aliEnRIK:
i dont know much about that kind of thing rik , but i know that some mp3 tracks , played from a usb stick by my marantz cdp sound better than some cds that i own ..
JoelSim:APatel8:
Cheers guys.
Using MP3s?
Yep 320kbps MP3's.
Don't be conned into believing the whole bitrate nonsense. Most people can't tell the difference between say 192 and 320 and then CD quality. I use 192kbps, it's absolutely fine. The critical thing is the quality of the recording in the first place and that just shines through no matter what the bitrate is.
the record spot:Don't be conned into believing the whole bitrate nonsense. Most people can't tell the difference between say 192 and 320 and then CD quality. I use 192kbps, it's absolutely fine. The critical thing is the quality of the recording in the first place and that just shines through no matter what the bitrate is.
Thanks - I'm not. As I said earlier, I was very happy at the beginning, but now the music is beginning to sound a bit lifeless to me... the top-end is poor and the bass isn't very well controlled - I am no expert, but I think the amp and probably the cabling are the route cause. Most of the MP3s I listen to are 320kbps, and I have heard different set-ups sound brilliant with MP3s via DAC. Definitely will not be changing the speakers either!
Mate (Vinny7) is bringing round a Marantz amp on Monday and Chord Company cables so I will see how that meshes - I am sure he will be able to offer more advice aswell about what this current set-up's flaw is!
Hello APatel8,
May I suggest, before you spend any money changing your equipment, you contact Arcam's service department. Explain to them you're sure the sound from your A85 amplifier is less dynamic than it used to be. You never know, the amplifier may have developed a fault over the years which is causing this problem. The Arcam guys are very helpful, so it's worth asking their opinion.
Very best regards,
Steve Reichert - PR Manager, Armour Home
As you stated earlier in this thread, I think you missed out a critical imho in there somewhere. The difference between 192kbs and 320kbs is clearly audible on an ipod through my car stereo, differences in bitrate are not nonsense.
Really? Wow, 'cos on mine going to and from Devon in the past fortnight, I had some of the best recordings going at Lossless, 192, 320....and you know, rather like on my iPod and Sennheisers or on my stereo, you-just-can't-tell.
Well, if you're enjoying the music, it really doesn't matter at all - context is everything. However, I wonder why everyone on these boards gets so vexed by the nuances of sound reproduction if 192 bps mp3s are just as good as CDs or lossless files?
I'm definitely still with Rich on this one - even Spotify Premium (320 bps) - very pleasant indeed - just doesn't have the sparkle or tight bass that I get from my CD player.
Rich27, i was just wondering why you use the hiface. do you hear a difference between it and optical into your dac?
I dont think bitrate could be classed as 'nonsense'
JoelSim:APatel8:
Audition.
Firstly, the synergy between Creek and MA is cracking, however, like Joel said, there's more at play here than just the amp.
aliEnRIK:
Neither do I, it's the resulting golden eared claims that people can tell a difference between 192, 320kbps and an audio CD copy that I'm referring to.
Sorreltiger:
You're right about nuances. Personally, I couldn't care. But some claims around what makes music sound good are often based on hearsay, myth and opinion represented as fact. A bit like the wisdom of crowds. That is, of course, assuming the crowd makes the right or wrong decisions in the first place.
the record spot:Sorreltiger:
Get off your high horse, if you really don't care why do you get so wound up about the simple opinion of other people. You obviously believe that yours is the only "right" opinion and others are not allowed to express their own. Personally I couldn't give a monkeys whether you can hear the difference or not, that is up to you.
In my earlier threads I was just trying to offer some simple helpful advice to the OP, when it gets reaction like yours, I won't bother again.
