MUSICRAFT:APatel8:
I'm completely amazed. The Rotel RA-1062 sounds absolutely perfect! It's exactly what I wanted. The sound is more 'in your face' and the music has come to LIFE finally. At even very low volume the sound is brilliant, where as on the Arcam I had to keep pushing it higher to get some oomph. Very happy, and have ended up paying £50 less for this.
Also replaced the interconnect as I said earlier in the thread, now using chord chameleon silver plus.
I think I will also replaced my QED Silver Anniversary with Chord Odyssey 2 shortly!
Hi APatel8
I am pleased to read that you are also happy with the the RA-1062. The A85 is ok however there is a rightness about the RA-1062 which imo the A85 just does not have. Hence why in the 92 demos i did of the A85 versus the RA-1062, 90 of my clients chose the RA-1062 regardless of associated components used and in the process saved themselves some money.
The RA-1062's balance is very well judged without tipping over the edge and becoming bright.
Btw, i will again suggest you consider using generic speaker cable as this will do the trick nicely with your RA-1062 and RS8 speakers.
All the best
Rick @ Musicraft
Hi Rick,
Thanks for the recommendation, I owe you one!
What is this 'generic speaker cable' you talk of, and where can I get it. Would it give better results than what I have at present, and why? Sorry for the 100 questions - just haven't seen that type of cable recommended on here 🙂
Hi APatel8
All the best
Rick @ Musicraft
Hi Rick,
