camcroft
Buy something decent and you will have none of the problems mentioned.See what you've started! @plastic penguin 😀
They're right about all cartridges giving both positive and negative voltages (with respect to a central 0v).Project also claims that the positive and negative voltages are always being generated by both MM and MC:
Which obviously allows for a balanced connection in terms of pro-audio.
I see, the L- is the inverse of the L+ hence they are the cold and the hot.Which obviously allows for a balanced connection in terms of pro-audio.
The way I see it Vincent, it's got everything to do with it - in principle, it's identical to pro balanced microphones.this has noting to do with common noise rejection as we know it from professional balanced connections.
The mic is mono, correct? For stereo you need 4 cores.In the mic, the voice coil connects, via 2 cores and a ground, to the balanced mixer.
Yes.The mic is mono, correct? For stereo you need 4 cores.
I was totally wrong footed there. Thanks for the clarification.The way I see it Vincent, it's got everything to do with it - in principle, it's identical to pro balanced microphones.
In the balanced cartridge, each channel coil connects via 2 cores and a ground.....to their X3B balanced box.
That's what genuinely takes this above snake oil territory 👍
Yep. This thread is deeper than expected.See what you've started! @plastic penguin 😀
It was quite a revolutionary move for Project to come out with a system like this, one can hope that over time the whole set-up might be produced more cheaply.And for deep pockets, certainly!
According to @daytona600 Thorens, Teac and many others use a balanced set-up.It was quite a revolutionary move for Project to come out with a system like this, one can hope that over time the whole set-up might be produced more cheaply.
I very much doubt it but would be interested to see examples. Did I miss his input into this thread?According to @daytona600 Thorens, Teac and many others use a balanced set-up.
Thorens / Teac and many others offer XLR balanced outputs
XLR Fully balanced done correctly sounds better & Fitted as standard to all very expensive hifi components & AV
XLR connector/cables are 95% cheaper than audiophile cables as made & used in Vast volumes globally
View attachment 4870View attachment 4871View attachment 4872
That's what he said a page back.I very much doubt it but would be interested to see examples. Did I miss his input into this thread?
To my mind Project have the only balanced analogue front end option to date.
Yeah I do remember seeing the Thorens one now, but I'd forgotten all about it.According to @daytona600 Thorens, Teac and many others use a balanced set-up.
Still can't see it on this thread? what was the post number?That's what he said a page back.
Post #71.Still can't see it on this thread? what was the post number?
That's really odd, no wonder I could see it, l don't have a #71.Post #71.
I have figured it out.That's really odd, no wonder I could see it, l don't have a #71.
Mine skip from 70 to 72 for some strange reason.
No, by their very design it would appear, and this is why Project have fitted a Quintet, although I am no expert here.Is it the case that there are no balanced MM cartridges?
Actually Rega introduced the Planar 6 + Ania MC cartridge in 2021? Review here. It includes a separate linear power supply but no balanced outputs.One reason I can think of why nobody brought MC in this price range before is that MC cartridges don't have replaceable styli. You have to change the whole cartridge. There are a few exceptions but not among the Quintet series.
Just because a company fits a MC rather than a price compatible MM doesn't necessarily mean it has to be balanced. It's only a relative new approach by Pro-ject.Actually Rega introduced the Planar 6 + Ania MC cartridge in 2021? Review here. It includes a separate linear power supply but no balanced outputs.
