Question Two questions about cartridges
Hifiver
34
13
4,545
I am considering upgrading to a cartridge costing nearly £1,800 on a turntable I have, which was £2,000 new.
My dealer is coming to my home, so I can hear it on my current set-up, prior to deciding.
He is going to remove my current stylus and fit the new one, given that I am inexperienced in doing so.
Q.1 For pricey set-ups, do you prefer a dealer to fit a new stylus, when you purchase one irrespective of your experience?
Q.2 Has anyone else here spent nearly as much on a cartridge as they have the turntable?
Q1: No dealer needed for me (at home). I have quite a lot of experience with turntables, cartridges...But if he can help you with set up, why not. You may learn from him.
Q2: Yes, some turntables deserve this level of cartridge.
By the way, which turntable do you use?
Pls. let us know your experience with dealer and new cartridge. BR.
Reactions: Paul AJ
Yes, I did, but mine was 60 times less expensive than what you're buying.
You and dealers are good for each other 👍
Well he's certainly good for his dealer.....
and no, I wouldn't consider fitting a cartridge of that price to a turntable of that price unless I knew the cartridge and tonearm in question.
Do tell exactly what you have.
A1. No, but only because I worked for over a decade at a hifi store, so could fit cartridges in my sleep back then! These days I prefer a detachable headshell though.
A2. Yes, but not for a long time.
The respective prices may not be relevant, but knowing the rest of your kit, especially the phono stage, is essential! 🙂
Aha! My question was directed at the OP
Oh right, of course👍
I'd like to think that expectation bias (and dealer influence) won't be an issue when the OP gets his home demo.
But I'm realistic. Who couldn't have expectations?
I've had expectations, prior to genuinely blind testing cartridges and phono amps.
Based on my experience with that, good advice to the OP might be - don't do any blind testing after spending £1800.
Reactions: DougK1 and Al ears
I only wondered, as I know some people buy cartridges online.
I prefer dealing face to face with a dealer.
I would say let the dealer do all the work because when you are spending money like that I would want my system set up correctly & if you trust the dealer then you can trust yourself to know the right way to use it after.
Q1, In your case, I recommend to use help and visit by your dealer at your home. In my case, I "use" a good friend, who comes with all equipment and we "play" together. It is also very dependent on your turntable. If you have Rega, even Rega Naia is realy easy to instal also cartridge Rega Aphelion 2. No need for dealer.
Q2. Yes, why not. My Rega Planar 25 was in 1500 Eur region zears ago and I installed Benz Micro Glyder MC cartridge on it (value some 1200-1400 Eur that time). This is very depending on quality of your turntable and its arm. BR.
