Mucking about with cartridges...
record_spot
754
654
19,770
So, I popped up to Edinburgh today, had a couple of things to get sorted on the car and later dropped by Thorn Records in Bruntsfield (one of the city's popular residential areas). Thorn's a fairly recent arrival in the last few years, but picked up a few rave reviews and was listed on the Financial Times as one of the best in the world - not quite sure about that, but it's very good.
I leave with a few albums - Skids 45th anniversary reissue of Days in Europa, Moby's excellent Resound NYC double and The Cocteau Twins compilation The Pink Opaque which has a number of their early-80s tracks including The Spangle Maker and Pearly-Dew Drops. back in the car and drive home looking forward to hearing the new stuff.
I notice that my cartridge stylus (Benz Micro Gold cartridge) looks a little off-centre, so decide to swap it out for a AT-VM540ML that I have with not too many hours on it. In my old flat, it had sounded way too full and bassy. Overpowering really. In my new place, with a different layout, etc, it's fitted in seamlessly and sounds great. The balance is good, it's a weight sound but not excessive and the treble is as good as always, something I've always appreciated in AT cartridges.
I'll give the Waters Lockdown Sessions album a run tomorrow to see if that's more satisfying a listen with the new cartridge in, but for now...time for the Cocteaus!
Interesting to hear the 540ML sounds bassy. I have it and I always found it a bit lean (some say neutral - as might be), especially .compared to the 95ML.
Better (overall) with a RigB body but it still leaves me desiring something a little fuller.
Once again, it could well be the acoustics of the room as you have found by moving to a different place. Out of curiosity, is the rest of the system the same?
I got an AT95ML to replace the conical that came with the Technics. It's fine, nothing much to complain. I got the cheap Microline because the options got confusing and I got a good deal inclusive another headshell. I was initially shooting for a 540 and then Ortofon Bronze and may still do. I usually used to prefer Ortofon's. They are a little more mid centric and forward whereas AT's tend to do soundstage better but at cost to fullness. They sounds 'airier'. Have to say the 95ML sound pretty balanced but without having an Ortofon here to compare I can't really comment on current differences.
Part of this I think comes down to the capacitance and loading between the cartridge and the tonearm and maybe the phono stage. When I was in my older flat, the 540 just sounded too lumpy and weighty, which is when I opted to go down an entry level Moving Coil cartridge route.
In the new flat, the speaker arrangement is different, wider apart (7.5 ft or so) while I'm a little closer facing across the breadth of the lounge, rather than facing down the longer part of the room, plus, I didn't want the stereo or TV to be sitting directly in front of the large (and effective!) radiator.
Otherwise, the stereo is the same and listed in the signature below.
Reactions: Entrigo
Room acoustics have a Huge affect on sound around 60-80% is the room not your speakers/cartridge
Sounds Bassy
could be a room node , move your seat forward or Backward or try moving speakers further into the room or out from the corners
Sounds Bassy
This ain't my first rodeo Chuck...oh and when nothing else changes but the cartridge and the sound changes significantly, I think I can make my own assumptions here.
When I bought my Technics SL-1210GR in Jan 2023 I also managed to get an AT VM95ML at a bargain price, so thought it’ll do until I get settled then I can maybe upgrade in a few months. However, it’s been so easy to live with, quiet, tracks anything, decent tonal balance, etc., that I’d quite forgotten about changing it!
I’m sure something else might work well - I had in mind a 2M Bronze - but frankly I’m really pleased with the good old Audio Technica!
Ditto. I've bought the 95ML to replace the 95C. Worthwhile change but the damn things are fugly.
AT brought out the X range of MM's including the AT-VM750xSH with Boron cantilever for around £300. Again, seems fantastic value but only a mother could love that ...
Am I being shallow? 🙂
Yes. Looks are not everything take my AT-VM95 with RigB body which is black partnered with a Paratrace black stylus doesn't look much but it sounds really good
but saying that what it cost me it should.
It never really occurred to me, though the red stylus is quite smart! Plainer designs are usually easier to align, though I’m not a ‘swapper’ these days, more a fit and forget!
Reactions: DougK1 and Al ears
It deserved a gold or silver colour, I reckon!
Indeed. Unfortunately metal (gold) is reserved for a higher range. Still, here is something I made earlier ... 😉.
Anything better than this blue.
Reactions: nopiano
Very nice. I would guess that ultimately the body/ies of the 95 series may be the limiting factor? It would be interesting to hear whether putting the above nude MR on saphire on a VM95 would result in a preferable sound to a AT-VM745xML (boron).
I would put my VM95 RigB with Paratrace stylus way above the standard VM95 as the stylus costs more than the ML complete cartridge.
Appreciate that Camcroft even though I do not know where a Paratracer stylus differs from AT's own nude Microline. My remark was more directed towards the new'ish AT-VM750xSH (or equivalent slightly cheaper ML) both cost around the £300 mark and both have either a Shibata or ML on a boron.
To be honest, I only got the VM95ML as I couldn't decide between either of the above two. I may still go for one of the above or an Ortofon Bronze.
The red ML is the best...... besides my Paratrace one which is only available from one place that I know I think that they have them specially made.
I wish the brown Shibata was another colour but the Red ML is the one to go for if you have a small budget for the time being... I also bought myself the Linn Adikt Cartridge with the Gyser ll Styli which they class as the replacement for the original K9 Vital Styli & that is great if you have the cash.
Reactions: camcroft
