Al ears
Why oh why buy a balanced phono stage if you intend to use a Moving Magnet cartridge, or have I missed the point?This is a brilliant thread, so much helpful discussion on these balanced TT set-ups.
At the end of July I will be having a demo of Project's X9 with a DS3B Phono stage, and if all goes to plan I will be taking to the DS3B home on loan to test out as a MM phono stage to see how it compares to my Rega Fono.
My aim is to see if the DS3B is a step up from the Fono in terms of sound quality, if it is then does it also give me a potential 'In' to a balanced system at a later date via a Project TT or alternative.
There is still a question over how far up the chain that 'balance' connection could or should be maintained. Many amps now have balanced inputs and the DS3B has balanced outputs so I wonder if there would be an audible difference between the TT balanced to the DS3B, then balanced into an amp compared to a set up where the TT balanced to the DS3B and then RCA to the amp.
This is going to be an interesting journey.
Apologies, just re-read the rest of your post.
As I have previously stated once the balanced signal has been stepped up to line level and got to your amp then the major benefit is concluded, in my opinion.
If by X9 you mean the Project Xtension 9 then I don't believe this turntable has balanced outputs, could be wrong.
 Facebook
Facebook Instagram
Instagram
