- Jul 22, 2015
- 1
- 0
- 0
Hello, I already have Dali Zensor 1 speakers, which only just about fit on my shelf (depth-wise), so I can't really get anything bigger; which rules out most other more expensive audiophile speakers. Underneath my rather modest desk also sits an SVS SB-1000 subwoofer. I do not use a receiver at the moment, because I couldn't afford one at the time, so I'm running on an Amptastic Mini-T TA2020 (the original version) because I heard good things about it, it's cheap and isn't affected by all the electronics you would get in a cheap A/V reciever.
The only way I can think to enhance my experience further is to purchase a middle speaker for 3.1 sound, because I don't have the space or inclination to go full 5 or 7.1 channel at the moment . Now my only concerns are:
1) If I hook it up with my current setup, I'd have to buy another amp, split the sound coming from the source RCA input so that they go to both amps. On the middle speaker amp RCA input, I'd have to have a stereo-to-mono adapter because there's likely only 1 channel's worth of speaker wire connectors on that middle speaker. Then the middle speaker would be outputting mono sound with a separate amp to the main speakers, which would still be normal stereo. However, then I will have messed up the sound-stage, wouldn't I?
2) If I purchase a proper A/V receiver to do the job for me, my current amp would then go unused, but then I'm guessing the sound quality would be affected because, to output in 3.1 sound, I'd wouldn't be able to use PURE DIRECT mode. I'd have to enable a dreaded Dolby Surround mode to create a proper sound field spread between the speakers. Isn't Dolby Surround lossy?
Please advise if you can think of a better way of wiring this all up, or whether I should even bother trying in the first place.
