Worth upgrading TV to 1080p
As I bought my TV back when HD ready was the norm - I'm wondering if it's worth upgrading my TV to a decent 1080p set.
If so what TV would you recommend for around £1000 budget?
I'd be using it mostly for Blu-ray movies, and size wise possibly a 40/42" 1080p set
At that size then yes it's worth considering, but try to see Blu-ray on your current set and then on the ones you're considering, and see whether the difference is worth it for you.
As for which sets we rate, see our Best Buys section...
Great Advice, Thanks Andrew!
I like to get my facts right before falling into the "Salesmans" trap at my local store
Much appreciated
