MattSPL:Tarquinh:MattSPL:Tarquinh:MattSPL:
Very nice machine.
Just a tip, seen as you have the case off it. Replace any fuses the cd player has with Hifi Tuning fuses and use a good quality mains cable. This will bring the cd player to another level of realism. Amazing. I take it you haven't heard the T+A then? The only extra realism it could bring was if it could project holographic images of the musicians and singers into the room
I take it you haven't heard hifi tuning fuses in a good system then. Or a good Wadia machine
No, because a good system doesn't need hifi tuning fuses.
Believe me it does. The better the system, the easier to hear the improvements. A standard fuse isn't made within tight tolerances and uses cheap copper alloy as its fuse wire. Copper oxide doesnt conduct well, so a fuse deteriorates over time.
A hifi tuning fuse uses pure silver as its burn wire. This conducts better than copper and silver oxide is a good conductor also. Simple.
Believe me, it doesn't. Only an fool would go out and waste £25 on such nonsense. Me, I'd rather give the money to charity, where at least it might do some good.
Very nice machine.
