Probably a Sony 4K PJ, 1500 lumens, HDR etc etc.
"Throw" about 12 to 15 feet. Screen size 140 to 150 inch ish diagonal. 2.35:1 if I can get one with the right material, 16:9 if not.
Must be acoustically transparent as it will cover all three fronts (hopefully).
Room is a dedicated HT room, no windows at all, with the only light getting round cracks around the door, most of which can be semi-covered if necessary.
Walls are mushroom colour with normal American "orange peel" texture, not flat like a UK wall, so should scatter light quite well. Carpet is light brown. Might get away with changing that but The Memsahib is most unlikely to put up with black walls ceiling or carpet.
Colour?
Gain?
Colour?
Gain?
