Been looking at a few of these online recently. I can't believe how much money they cost for a few pieces of powder-coated tubular steel welded together, particularly one deep enough to safely hold the Thorens (needs about 14.5" / 37cm). There doesn't seem to be enough competition to drive prices down.
I really can't see why I can't get away with using some sturdy microwave brackets. If I drill the arms to accept adjustable speaker spikes, they will slot into the cross-head screws that hold the turntable's feet on. Couple of nuts on each, level the turntable and lock the spikes in place with the nuts.
I just need to be bang-on screwing the brackets to the wall, so that the horizontal distance between the spikes is the same as the turntable feet. Easy to practise though before I drill the holes in the wall for the second bracket: take the base off the turntable, balance it on the brackets and mark the wall where the last pair of holes are to go.
All in, change from £20 including the spikes + nuts, instead of ten times more.
