Using SKY HD box and PS3 with DAV-IS10
If I am using SKY HD box and PS3 with DAV-IS10 I would need to feed audio to the DAV-IS10 from the PS3 with an optical cable right? But the same goes for the SKY HD box as well I think.
Is there a way to get round having to continually poke round the back and swop the two optical cables around?
Not got a PS3, but I assume from the question that there are no co-axial outputs that you could use from either the Sky box or PS3?
Otherwise I have seen that there ARE optical spliters out there. Not cheap and I don't like the sound of the principal myself, but if its what you need, then it's what you need.
David.
gregch
34
I'd also like to know the answer to this one! I really like the look/sound of the DAV-IS10, but I'd like a proper HD player and be able to connect that (probably PS3 or BDP300) AND the Sky box (and, ideally, a Wii) to it. Is that possible?
Clare said the DAV-IS10 has optical, coaxial and analogue inputs - but I'm not sure what that means in terms of what could be connected to what.
Andrew Everard
1,878
Sure I've covered this one before, but you can get round this problem with a simple optical switch like this one, available from most accessory companies.
