Might remove some money from your bank account...I don't think the RA Silencer could improve audio quality, my best guess is it might remove the pop when appliances come on?
Not mine!Might remove some money from your bank account...
If you hover over a user's name to the left of their post, you will see stats, including when the user last visited. Alas in this case the user hasn't been here post this thread, so I suspect you won't get a reply.@PH_UK do you still have the mystery box?
I've been ploughing through the Culture novels this year - up to The Hydrogen Sonata once more. Not sure I have an absolute favourite, but Surface Detail might just be it - might just be my favourite book, too.@12th Monkey
I did spot how long it was since they visited, what can I say? I am optimistic to a fault and can be very patient 😉
Good spot on the Ian M Banks reference 🙂
I would like to see a review of one of those boxes, one that includes a picture of the contents of the box.
www.audiosciencereview.com
so wood I.... 🙂![]()
Entreq "signal grounding" Measurements
Hello everyone. As some of you know, I signed up for making some measurements of the Entreq "signal grounding" box. If you don't know what that means, you are not alone :). It is a type of device where you connect it to the ground or negative terminal of your audio signals and it is supposed...www.audiosciencereview.com
So all the box does is add noise, what a surprise… Not!![]()
In fact, I've been using the same online name since the year dot - time for a change, I think...@12th Monkey
Further to the above. I can make wooden boxes, £20 + the cost of your choice of wood. I’ll leave the lid loose so, you can add your own choice of special piece of wire, to sit inside it…So all the box does is add noise, what a surprise… Not!
Think of all the money you can save, by just using a piece of wire to achieve a similer effect.
£20 is way too cheap for your target market.Further to the above. I can make wooden boxes, £20 + the cost of your choice of wood. I’ll leave the lid loose so, you can add your own choice of special piece of wire, to sit inside it…
Your new name, could be the start of a slippery slope...In fact, I've been using the same online name since the year dot - time for a change, I think...
Feel free to let loose with the full force of your bank balance, let Analogue seduction pricing, be your guide!£20 is way too cheap for your target market.
I wanted Falling Outside the Normal Moral Constraints - that might have been further in that direction - but was (alas) too long!Your new name, could be the start of a slippery slope...
