I did not say that "bigger speakers are easier to drive." I keep trying to explain further but your takeaway always seems to be this statement, and it isn't true. In fact I have said very little about "easy to drive."
Think of it as a triangle, and the three points are size, efficiency, and bass response. An engineer can move their design around this triangle, favouring one or another, but you can't have all three. Yes, you can make the same speaker more efficient (or produce better bass response) by making it bigger, but that does not equate to "bigger speakers are easier to drive."
In fact, I think I pointed that almost any solid state amp can "drive" any of these speakers just fine. An inefficient 80 dB speaker will blow your eardrums out in a living room if you put 10 watts through it.
What we are talking about it is how they SOUND. You are trying to make this too simple, Rob, by looking for simple numbers to explain a very complex interaction. That has been my point in every one of my responses: the sensitivity/efficiency number offered by the manufacturers is practically useless, and that you are being reductionist by equating a single sensitivity/efficiency number with "easy to drive." But you keep squinting harder, hoping this will make sense. It won't ever make sense because the numbers are mostly BS.
Manic gave an excellent example: Monitor Audio. Let's compare two similarly-sized speakers. The Bronze 100 has a sensitivity of 87 dB, and a nominal impedance of 4.5 ohms. The Platinum PL2 100 has a sensitivity of 88 dB, with a nominal impedance of 6 ohms.
So you tell me, which is "harder to drive?" I can tell you from personal experience that the upper reaches of the Monitor range soak up gobs of power. Don't even bother trying to run a Platinum speaker on low-power or low-end anything - it will sound crap. Ask a Monitor dealer, they will tell you! The Bronze series pair nicely with good low-hi-end amplification like Marantz, Cambridge, and NAD. WHF didn't love these 100s but they did say that they "rendered a huge sound" and that they go "loud and deep."
How would you know this from the sensitivity numbers, and how do they relate to this real-world outcome? You wouldn't, and they don't.
By the way, Monitor Audio do offer an important additional detail on the PLII 100 specs, that they don't mention on the Bronze, by giving a minimum impedance of 4.5 ohms at 160 Hz - this is their little hint to the knowing that these speakers might need serious amplification. Just be aware that this is more info than manufacturers often give.
 Facebook
Facebook Instagram
Instagram
