Is URGENT as I need to really order on Sunday (Screwfix) if extra fittings are needed.
I'm finally ready to mount my plasma on the wall.
I have a Vivanco PML 731S bracket (free with screen - tilting and looks like its decent quality), however I'm not sure how to fix it to the wall.
My instinct says use Rawl bolts although I have concerns about not being able to remove them if for any reason the bracket and or screen are changed later.
The brackets instructions say no fixings are supplied but as a part of my package (in the manufacturers sealed packaging with the other fixings) I got supplied some heavy duty screws with bolt heads and large plastic wall plugs (14 mm diameter plugs):
Question is what do I use?
The plugs are attractive from a demounting point of view however I'm worried that just being oversized plastic plugs they might pull out. The rawlbots are attractive from a secure mounting point of view but could cause problems later being non removeable.
Anyone from What HiFi have any advice on fixing systems?
Al
Al
