billybifocals said:The reason why ive got RGB Full Range (HDMI) set to Full is because "Limited" delivers a more subdued, albeit more naturalistic, color range, while "Full" produces both brighter and richer tones on both ends of the spectrum. As a result of the "Full" spectrum, many intermediate shades get lost in the mix. On the other hand I find that "Full" is better for this particular samsung TV. Its all about preference at the end of the day. I can't see there being much difference from one identical model of this tv to another. That's as mad as saying one car built on an assembly line will have more horse power than an identical car built on the same assembly line. That makes no sense. The only thing that might cause differences is tv firmware. This tv automatically updates itself anyway.
What I am saying is that whilst the PS3 games will (In some cases, but mostly not) use the full RGB colour pallette, blurays and dvds are 8 bit and so all you're doing is converting the signal. As with any conversion going on, errors are than possible s it converts on the fly.
In other words, it could look worse than staying at LIMITED (Which its encoded in to start with : so no conversion going on)
Any ISF engineer would tell you that the same model number will have slightly different settings. Setting tvs has nothing to do with cars (Although I am 100% sure if you could measure the horse power very accurately, there certainly would be differences between the cars)
