Help me pick my next Headphones! Currently have LCD-2 /Focal Clear
Mythy
First let me say hello! I been trying to decide on a new pair of headphones for a long time and I figured I'd stop by and ask you all for some recommendations.
Currently I have Focal Clears and LCD-2 Fazors. I have a Burson Conductor 3 Reference as my main source. I been wanting to upgrade my setup for a long time. I love the bass on my LCD-2's and the clarity of my Focal Clears. I also have DT-1990 Pros but there just too bright. Basically I'm looking for a Focal Clear and LCD-2 hybrid of sorts. My budget is around $1000. I been considering the HifiMan Arya Stealth and at $600 its a easy purchase. What else should I consider and is this a good choice? I mainly listen to Techno, EDM, and R&B for my music but I also use these for all my movie and cinema needs.
P.S. If you think theres a better amp/DAC for my needs and have compared it to the Burson please let me know!
Hi Mythy welcome to the forum.
I love the sound from planar magnets, the music doesn't suffer from distortion as much as dynamic in the low frequencies. I assume you're looking for open back headphones.
Many people seem to favour the top end Sennheiser's, they have excellent bass but I've also heard from others, these tend to be a one trip ponies, yes granted, bias and unqualified comment from me!
The discontinued Focal's Elegias I use to own, super impressed me. Does everything right, not bright, well balanced headphone. I suspect this is the signature trait for all Focal headphones.
The Beyerdynamic Amiron headphones I own are based on the DT1990 but tweaked not to sound like studio headphones, silky smooth, very similar to the Focal's.
If you're interested in the HIfiman's HE1000 Stealth are greatly reduced - see links below. Slightly above your budget.
Caveat, apologies if you're not UK based, I suspect you'll find similar prices.
If you want to be brave, on AliExpress they're selling the version 2 for the same price! Always make sure it's a reputable seller.
1742381233733.png https://www.amazon.co.uk/dp/B09LV6W...de=osi&th=1&psc=1&ascsubtag=ecSEPowjjm8fselob
The HifiMan - ARYA Stealth makes perfect sense as they're priced sensibly below £600 - see link
I have bought a used pair of Focal Elvgias. Using them with an Arcam rHead amp. I am disappointed as the headphones sound really tinny
Do I need a better quality headphone amp?
Have you used your Arcam headphones socket with other headphones?
And, were you pleased with the sound?
Arcam is a decent amplifier but not familiar with it's headphones output.
Perhaps someone on the forum can comment.
I use to own the Elegias and tinny is not a facet of these headphones. So something is off.
Have you tried replacing the cables?
Good luck 👍
I've never owned the Focals but many on here have and I've seen zero complaints from users. So it's either you are unused to their sound signature or there's something wrong with them. My personal opinion is that a cable change will make zero difference.
Doug, sorry my bad, I wasn't clear, that the cable might be faulty, possibly a loose connection with the wiring. 🙂
Well I ordered a pair of arya stealths to see how they sound. There primed so its a whatever but I do prefer the HE 1000 look. Might upgrade if I like these.
I have another question tho. Can a garbage 2 channel power amp cause a 6-8dB Gain spike around 400hrz? I have been having issues with my desktop setup and despite several dacs/speakers I always have the same huge hump in the midrange. Makes voices very warm. I was EQing it out but I reinstalled windows and don't feel like going through the trouble. I'd rather fix the issue. The amp is a old emotiva Basx A-300. Speakers are SVS Ultra bookshelfs and Polk LSiM703. Both graph out nearly identical with the same huge hump.
Arya Stealth's very nice. Enjoy! 👍
Your other question, regarding the spike, I haven't a Scooby. Hopefully someone with some background can give you the correct answer.
I'm tempted by HE 1000 but I'll wait until prices dip down a bit more.
I think I'll sell a kidney and get second edition HE 1000SE! 🤣
Well... I have the stealth's now 😕 Compared to my Focal Clears and my LCD-2's I find the sound to be too distant, a little leaner to allot leaner compared to the focal and the LCD-2. The treble is highly detailed especially compared to the LCD-2 however it can be downright painful. Definitely not chill headphones for late night listening. Everything sounds more distant. At times they sound lean in voices. I have not compared them to my Focal clears yet in detail. Everything was powered by a Burson Conductor 3 Reference (7.5W @ 16Ohm)
Cons:
-Built like crap, cheap feeling, Garbage Cable, Garbage Box, No case?!
-Awful headband
-Creaks while wearing
-Treble is painful at times
-Sounds analytical, Distant
-Lacks intimacy, Sweetness
-My wife makes fun of my Hat dryer on my head
-Lacks any type of Magic
Pros:
-Detailed
-Only $600
-Decent Bass
LCD-2
Cons:
-A tad bit dark for me
-Slightly thin on detail retrieval
Pros:
-Sweetness
-Intimacy
-Base Impact
-Build Quality
-The Cable, Case, Accessories
-Not Painful to listen to
