Macspur said:
I would have been surprised if it had gone without a hitch, these things rarely do, but like you say
it may well be academic anyway.
Mac
Cheers, Mac. All looking good; more on this below.
DocG said:
Forewarned is forearmed. In my case, the speakers will end up on a cupboard against the wall, so I'll keep your findings firmly in mind when demoing the Dev with Cremonas myself. (Note to self: don't buy without home demo... once the house is finished :doh🙂
Doc, I fear that will be a bad place for Cremonas, with their rear port. I'd also worry about bass boom though the cupboard. Maybe a nice thick granite slab to sit the speaker on? One advantage (for you) of the Vivids is that their reflex port fires forwards.
James7 said:
Good to hear. Foam bungs in the ports might help. This will reduce bass extension, but placing nearer the wall will boost it again. It will certainly tighten things up.
Thanks, James, that's on my list of things to experiment with. However, I'd rather go the bass trap route: better to cure the room than mess with the speakers' output, I think. Also, sitting the Cremonas close to a wall does affect their imaging (as I should think it does with most speakers).
Now obviously you can't leave a new pair of speakers unused, so this morning I took some kit out of my study and set up a temporary system downstairs, with a (modded) Sonos going into a (heavily modded) MDAC into a Cyrus X Power. The difference from the Dev is pretty obvious. This system has a rather thrashy top end, a bit of grain in the upper middle, and quite a bit less grunt down below. One advantage is this lack of beass heft, which means the boom is mitigated slightly.
But oh do these speakers sound fine! The three qualities I'd pick out are their speed, their coherence, and their very sweet tone (despite the hint of graininess). They manage to be hugely tuneful and analytical at the same time, and the one isn't bought at the cost of the other. I love the way they see right into the structure of the music and still let you experience it as music.
So I have a couple of days of listening to this temporary system (which ain't bad at all) before the shiny beast arrives next week.
Matt
