As davedotco has correctly pointed out, you can check the specs of both your amp. If the gain mentioned for both amps is the same, then you can control volume for both the amps with a single remote control.
From my limited reading on the Internet, bi amping in this fashion, will give the benefit that each amp will see only one driver at a time. This increases the amps ability to cope better with the impedance change of a single driver. So the amp can output the same power as before more effortlessly, leading to less distortion. Thus, though the total power of your system will be the same, as the lower powered amp between the two. The clarity and dynamics should theoretically improve.
Will wait for your feedback after your experiments to see if this is right.
Maybe I should stop here, but In case you want to take your experiments a few steps ahead. Next step will be to feed only the mid+treble frequency to one amp, and bass frequency to the other. This will require a external cross over between your source and your amps. A mini dsp 2x4 can do this ( please read further on Google if interested). Theoretically again, this will enable your amp to see a limited bandwidth singal instead of a full range signal. This should again decrease distortion.
Disclaimer : As I mentioned before, all my above is from reading on the net. And there are people who claim benefits from doing the above. And there are a majority of the people who claim no difference, except an extra expenditure on speaker cables.
