Blacksabbath25 said:no I do not think so if your on about the Exit 1 & Exit 2 thing I had that on the cd6005 but I have looked for that on the cd8005 but does not seem to be on there . I have only had it for a day so far so I still kind of messing with the sittings still and still testing it with the irdac still setup on the auxiliary input and the analogue is setup on the cd input so kind of switching it between the 2 inputs but there is definitely a sound difference between the arcam irdac and the on board dac and my wife hearing the differences and she normally hopeless at noticeing stuff like that . No I no the sa8005 uses the same dac as the cd6005 now what I want to no is what makes 8005 different from the cd6005 apart from the dac . I no it has a different power supply now what would this do to sound ? Better transport , different display, a heavily built case then 6005 has . Why would marantz make 2 models of CD player with the same dac inside ones a budget CD player and the other a mid range model what would be the point in upgrading surely what makes this 2 models stand apart from each other surly it's not the sacd function that your paying for . Hopefully someone with component understanding will tell me as I am interested.gasolin said:Do you use the sound mode (sound ex) the sa cd8005 manual say nothing about the sound mode but it's there on the CD5005/6005
Tried it my self (marantz cd5005) i feelt one connection was a bit brighter ( i actually can't remember what i choose to use, the option that was brighter or more neutral) the biggest difference was the cable, not the same brand, optical was a danish brand (argon red) and the other i use atm qed performance graphite (analog), that may have had an effect on the sound.
Do you use cable from the same brand/model?
