wauuw you make more topics,threads then i do.
As stated theres no dac in marantz PM8005.
Do you use the same cable with or without using your arcam dac?
I mean not excatly the same, but analog/digital from the same brand,model
Slice, Not odd, since i guess people like Blacksabbath25 who has a Marantz PM8005 uses a cd/sacd player with a better dac then there is in the cd5005,6006,PM6005,7005, which should have the same dac, what i also find odd is the PM7005 has only 1 set of speaker terminals but the PM6005/8005 has 2 set and the PM8005 have midrange eq/tone control i mean it's sort of the entry level high end amp and theres a midrange eq/tone control,WHY? Does the PM8005 have midrange problems or is the speaker you match with the amp speakers that needs to be adjusted in the midrange?
