Which of these DAC's is "best"?
Ohmish
18
8
18,525
Hi
I got a Yamaha R-N600A receiver amp, and just bought a used Yamaha CD-S300 CD player/deck (don't have it yet)
Both have optical connection. And I'm wondering if I should use it or not
Which unit do you think has the best quality DAC?
The R-N600A has "SABRE ES9080Q 384kHz/32-bit (ESS)" DAC
CD-S300 has "Burr-Brown 192kHz/24-bit" DAC
If the R-N600A has the best DAC then I will use the optical connection and let the receiver handle the conversion.
If the CD-S300 DAC seems best then I will use its analog outputs instead
Maybe it's much a matter of "which sound character do I like most" of the two DAC's, and maybe I gotta try it out
But would like to know which one is technically best
Thank you
Like for like price points, the source component will usually have the better DAC (generally speaking), as there's usually a lot more inside an amplifier than a CD player, especially when you start adding phono stages and streaming etc. Of course, it'll be more down to the implementation than the DAC itself. If you have good quality interconnects, the DAC in the CD player will be a good option, but if they're real bargain basement, go digital and get that digital signal further before decoding it to analogue.
You may find a little "character" to the Burr Brown DAC, with the ESS being more "there you go, that's it". If you find yourself hearing a discernible difference, there's nothing stopping you connecting it up both ways and choosing one or the other for certain genres of music, or for good or not so good recordings.
Reactions: Ohmish
CD-S300 is from 2009
R-N600A is from 2023
I expect the R-N600A to have the better DAC, simply less distortion, lower noise floor, etc. as DAC technology improved over time.
But that also depends on whether you want a clean clinical sound or a more colored charming sound (if that's the case. I don't know what it does yet)
IMHO a box that colors is simply not true to the recording and will never be.
Its coloration might enhance a bad recording but at the same time spoil a good recording. That is the problem with one trick horses, they color all the time, needed or not.
Better get something neutral and use DSP if you are in need of coloration.
Reactions: Dave_ and Gray
I looked at what AI says too (based on what it finds on internet/forums etc):
Burr-Brown Characteristics
  • Sound Signature: Perceived as warmer, richer in the midrange, and sometimes described as having more "weight".
  • Strengths: Associated with detailed instruments, a fuller sound, and can contribute to an excellent soundstage.
  • Considerations: Some listeners find the sound a bit "grainy" or less clear than ESS.
ESS Sabre Characteristics
  • Sound Signature:
    Often described as very clear, clinical, and analytical, sometimes perceived as having no distinct "character".
  • Strengths:
    Known for a very high dynamic range, a wide soundstage, and excellent clarity, supporting high-resolution formats like DSD and MQA.
  • Considerations:
    Can be perceived as "boring" or too analytical by some listeners after prolonged listening.
Key Considerations for Choice
  • Personal Preference:
    The "better" chip is subjective. Listeners who prefer a warm, full sound might lean towards Burr-Brown, while those who appreciate clarity and detail may prefer ESS.
  • Implementation:
    The final sound is heavily influenced by the entire DAC circuit, not just the chip itself. Even high-end chips like Sabre can sound poor with a bad implementation.
  • Context:
    ESS Sabre DACs are often chosen for high-performance systems and applications requiring a wide dynamic range, whereas Burr-Brown chips are sometimes favored for a more natural and musical sound.
With the latest off the shelf DAC chips you actually may want some colouring.
Hi
Thank you
Which is best? The one that sounds best to you!
Reactions: davidf and Ohmish
Good luck to anyone that does, I say.
That sort of suggests that the latest DAC chips are too neutral 🤔
...a bit like saying that my real chips taste too much like chips - unless I put salt and vinegar on them 😉
Not a problem for me, but each to their own.
I think the ESS chips may be too neutral - with additional neutrality added by Eversolo.
  • Sound Signature:
  • Strengths:
  • Considerations:
  • Implementation:
  • Context:
I wouldn't let AI be your guide on hifi at all. Or quite a few things.
Doesn't take long before its tendency to hallucinate come to the fore.
Reactions: davidf and Al ears
I know how it works thanks mate (IT contractor and last project was an AI project), and I still caveat it heavily. YMMV.
I kinda caveat it too mate. But I don't discard it, and it can be useful as a side-helper ish for some things
As long as you know that it's not facts or reality but just a robot opinion from a somewhat well-informed base
When it advised me that I could plug my Musical Fidelity X-LP phono stage in the back of my Cambridge 200M DAC to further improve my sound, that's where I got off the train.
And as for some of its decisions in basic maths...
  • Sound Signature:
  • Strengths:
  • Considerations:
  • Implementation:
  • Context:
Your better of Listening to them both but its not just the DAC its also what your amplifier & speakers add in the mix to the over all sound .
Its a choice you have to make yourself afraid and trust your own ears and forget what magazines say or the internet sound is a personal choice .
