Please help as I really need some good advice
I've just bought a second-hand Rotel RCD06 cd player and pair of B&W 685 speakers. Now all I need is a good integrated stereo amp and my first separates system will be up and running. Any idea what would work best with this combo?
At some point soon I would like to add a turntable. Also, if possible, a cheap way of playing MP3's I've downloaded on my mac and stuff on my old 1st gen ipod shuffle. Not sure how though.
A second-hand amp would be ideal as I only have about £250 and I would prefer to get a good used one than a cheap new one. I don't mind what make the amp is as long as it works well and produces the best possible sound with the speakers and cd player I have.
I was thinking of maybe a Rotel RA-01 or Rotel RA-04, but will the wattage be enough for the B&W 685's? Is there a better used compatible amp I could buy for around £250
Although this is classed as a budget system, the cost of putting the whole thing together is alot of money to me and I need this system to last for years to come.
Any advice as to the best reasonably priced amp, speaker cable and interconnects etc will be invaluable as I am sooooo confused.
Take care,
Rachel
PS My lounge isn't very large. I listen to mainly goth, industrial and electronica just in case you need to know.
Take care,
Rachel
