speaker jumper cables choice
System: NAIM CD5XS, NAC122X, NAP150X, FLATCAP2X, PMC GB1i's, NAIM NAC5 SPEAKER CABLE. Currently experimenting with either running the speaker cable to the high frequency posts or low frequency posts and then jumped to the other posts respectively. I have some atlas jumper leads on loan from a shop but need to buy some soon. I've recently had a post on here Re brightness and prefer the single run speaker cable to the bottom end first then jumped to the top end, seems to produce a fuller sound so, I want a jumper that will not be detriment to the top end and equally not make it any brighter, although such a small link will have negligible effect. Anyone any theories or recommendations on this?
P.s. I'm not into these Atlas jumpers as the spades are quite large, so much so, that using the links supplied with the speakers wouldn't be any worse.
Hey Ray, i recently changed my chord jumper cables to Cardas copper plates off e-bay for £20 plus P+P for four. I must say i'm impressed with the outcome and wont be going back!
hmmm, thanks. I've just had a look at these on ebay, seems to be a solid piece, I guess it would only fit if the distance between the posts on all speakers was the same?
Have you thought about a "F" Connection?
Your Naim dealer should be able to sort you out.
ray sheldon:hmmm, thanks. I've just had a look at these on ebay, seems to be a solid piece, I guess it would only fit if the distance between the posts on all speakers was the same?
They are sturdy plates but can be adjusted by hand. A bit of force and they're done. Easy.
